Multiple Vrscene from sketchup.
Hi, I just want to know if there is a way i can import different vrscene (trees,shrubs) from my sketchup model to vantage? As i used to render it over vray skp and i want to take it over vantage. Or if there is a way i can convert my vrscene to vrmesh to make it compatible to vantage. Would appreciate the response. Livelink over skp is amazing btw!
We don’t yet support .vrscene referencing from inside another .vrscene (or live link).
It’s on our todo list.
However, If you are building (or dressing) your scene in Vantage entirely, you can drag&drop .vrscene files in the Vantage viewport and those will be saved as references in the .vantage file.
You cannot use the live link in this case however.
Not really, as the .vrmesh files don’t contain materials.
Greetings,
Vladimir Nedev
Appreciate the response. I’ve done doing drag and drop over vantage however is just taking a while to populate the scene (without skatter plugin). Looking forward on the next update. Thanks
In this way of drag and drop is there a way to duplicate the vrscene? Instead of dragging one by one? Thanks!
Hi contexto_arquitetura,
No, currently there is no way to duplicate objects inside Vantage, but it is in our TO DO list and will be available at some point but no ETA at the moment.
Alexander
