Multiples VDB issue on render
hello,
3DSMAX 2019 / Lastest release VrayNEXT and PhoenixFD.
I’m importing multiple VDB sequence from houdini in phoenix simulator grid.
I use thoose multiple VDB to compose artisticly a Cloud scene inside 3DSMAX.
The issue is that we can see grid border inside the clouds
Do you know how to proceed to not have this issue ?
If you’re using V-Ray GPU, this is a known issue with grids with overlapping walls. A workaround would be to shift a bit the grids so that the walls won’t overlap.
If you’re rendering on the CPU - this should not happen and it will be best if you send the scene to support@chaosgroup.com so we can check it.
Cheers,
Ok, i have to deactivate exposure in camera when switching to CPU.
