Multiscatter sometimes is not rendering.
Hi! I’m using the build of 17/09, 3dsmax 2014, Multiskatter 1.2.00.12. Sometimes multiskattering objects are not rendering. Helps to restart 3dsmax. Please fix it.
how often does it happen, or do you see any pattern?
No, Multiskatter just suddenly no longer displayed on the rendering.
Has not been able to determine that it affects. This happens with any scene where there Multiscatter. Several times during the day, while working with the scene.
Multiscatter Object color texture - doesn’t work in corona?
I do this only happens with a Corona %(
i think there is a convertor script to convert from multiscatter to the coronascatter .. i test it already and the script is working ..
but, it will be great if corona can read the multitexture from Multiscatter, and the multiscatter object color .. :smiley:
I con confirm, sometimes multiscatter won’t work.. i have a scene where it doesn’t work anymore forma some uknown reasons
Same here. Randomply, Mulstiscatter doesn’t rendered. Only with Corona. With VRay was ok.
@Keymaster
in my max2014, i use multiscatter 1.2.0.3 .. when hit render, it always fail with prompt appear (see my attach) .. but, when i use other engine (mentalray and vray) its working normally with multiscatter. Is there any suggestion?
which version is the latest now?
thanks bro _^
Found the cause, fixed it. But let me just tell you: you have no idea about the amount of shit I have to crawl through for you every day! :smiley: :confused:
Please Ondra, tell me what was the cause?
I have the same issue and I found no clue in previous posts
what version of corona are you using? This is long fixed. It happened if the first render you did was in scene without multiscatter and then you opened a scene with multiscatter
