Hi!
I have the same problem as described here: https://forum.corona-renderer.com/index.php/topic,4238.msg29680.html with latest Corona build. The floor generated with floor generator using multitexture with material ID is not rendering correctly with back burner in 3ds Max 2014 on render slaves. However when I load the project in 3ds on the slave machine and render from within 3ds everything is fine. All the textures and output files are stored on local hard drive.
Edit:
Sorry for repost. I was searching for like an hour on the forum for solution and missed the topic with advice to upgrade MT to 2.0.1. You can close / delete my post.
