You/someone could write a script to quickly assign mattes to selected objects, then if you use a full set of material id’s and object id’s for the bigger things you can break the big groups up into individual objects in post. I think this is what you’re after isnt it?
It’s not a proper solution, but scripts could make doing it the long way take nowhere near as long.
