Hello friends, so I am not able to make the corona work in my max 2018, I always had it in the installed program hj my 3ds max was giving problem I removed it completely and I reinstalled, only that when I went to reistalar the corona it installs but it does not appear in 3Ds max, I’ve tried several things and nothing, can anyone help me?
I will put the print of the program so you can see …
What is the status of this? Are you still having some issues?
What you could try is installing manually as instructed here: https://coronarenderer.freshdesk.com/support/solutions/articles/12000038849
But instead of copying the files into “plugins” folder, copy them into “stdplugs” folder in the 3ds Max root directory. For some reason sometimes 3ds Max does not recognize the “plugins” folder and uses “stdplugs” for this.
