hi,
my first test Linearworkflow:
Render from VRay
Postprod. in Photoshop
Any questions, please ask ![]()
thanks!
hi,
Render from VRay
thanks!
Your raw render looks âdouble gammaâdâ. Youâd be better off leaving the raw render linear until final output from photoshop. (Use an adjustment layer or similar on the top most part of your layer stack).
Your comp looks ok, but you have some serious edge artefacts going (chair), and the fake dof is affecting the floor where the right edge of your render meets the extension" you put in. A tad too dark in the wooden panel for my tastes.
ummmm, thatâs quite a difference!
isnât the point of working in linear space that you view your renders in sRGB space in Max / Vray, and when rendered continue to view your images in this sRGB space in Post applications, but the data is stored as Linear float?
If youre using photoshop that much, theres no point in using linear workflow - itâll make very little difference to your final output if youre willing to alter it to that extent.
I dont really see the fuss with LWF anyway, but weâll leave that.
I like the first one but the materials seem a little washed out. Is the input bitmap set to 2.2 ? How about an image in between the two.
Yes - it looks double corrected. You shouldnât have to do much post at all if any. What you should see in the viewport should come close to what the final image should be. Are you using the Vray Frame Buffer or did you use the Max Frame Buffer?
Isnât the point of working in linear space that you view your renders in sRGB space in Max / Vray, and when rendered continue to view your images in this sRGB space in Post applications, but the data is stored as Linear float?
No, but that is one aspect of what can be done afterwards.
The main point of LWF is that everything is calibrated between programs:
1) Photos and Jpegs all live in the same gamma space as everything else youâre working on due to their original settings.
2) Max swatches/colors all live in the same gamma space.
3) Monitors all live in the same calibrated gamma space.
By having all three of these items âline-upâ or match, this is called being linearized or âleveledâ out. Itâs one straight line - there shouldnât be any curves if you were to plot it out. Therefore by having all three points above match, your final input and output between different programs and bitmaps should all be consistent across everything.
For instance, if you use Max standard/default settings and render out with Vray - the diffuse swatch colors that are rendered hardly every match with what you expected. You ended up having to go back into the material settings and tweak everything until you get it right. Since youâll never get it right, itâll involve a lot of post production work and even then it wont be accurate. This is due to the way Max itself works - by default it doesnât work in Linear space (one that matches your OS or most paint programs.)
Essentially, Max default settings are messed up.
Once you have your final image in Linear format, you can safely scale offset and exposure within a post-production tool by saving them as .exr or .hdr. But this step can be done with any image output by Max - but those wont necessarily be linear if not done properly. With proper linear setup, the final colors should be truer to what was originally intended.
Linear work flow does not actually dictate float, it just so happens to be a good fit for the more advanced compositing jobs.
The important part of LWF (or letâs call it âgamma compensationâ instead) is that you handle light ranges and hue\saturation a lot more predictably and spend less time fighting strange shades of light\shadow you had not anticipated. In addition to this, doing post work on a gamma corrected image (non-linear) produces errors, albeit small, but they add up. Why have artefacts when you can avoid them with the same amount of work.
Another point is that if you have calibrated your monitor to a set standard, and adjust your âgamma compensationâ for this, it is a lot easier for a co-worker to later on pick up your file and continue working on it, if you are away or on some other project. (As long as you both are aware of the âgamma compensationâ).
Edit: Ah, someone got in before meâŚdamn my slow typing.
Another thing I might point out: Even with 8-bit tgaâs or similar, you actually have a lot more room to tweak and comp if the images are linear. Trying the same with gamma corrected images gives you visible banding and other artefacts after only slight changes.
no, this is sRGB.
no, this is sRGB.
'Linearâization involves making sure all your applications and bitmaps line up in the same Gamma space. âWorkflowâ is a method to reproduce consistent results through a standard practice.
FYI, 2.2 gamma does not automatically mean âlinear workflowâ like most people think - itâs just a target number often used to get consistency. Your target numbers can be in theory all matched to 1.8 across all applications, bitmaps, and monitors and still be considered âlinearizedâ and a âworkflowâ if you and your team all calibrate to those numbers.
I should add to SVâs original question, that you are able to view the results if you choose to not âbake-inâ linearization using curves. You have two options/methods when using LWF - either to bake-in the results (as I tend to do - I donât do much post) or you can adjust the curves after-the-fact as Rob Niederhaus (spelling?) aka Throb originally showed in the very first LWF thread. By baking-in the results, you eliminate a few extra steps.
Just to add this to the discussion:
for me, âLinear-isingâ an image, means viewing the colours in a perceptually linear space - i.e. correcting for the response curve your monitor applies to the data. When viewing an unclamped floating point image in the VFB, on the monitor itâs initially very dark, but when applying an sRGB curve to the image, the data now appears perceptually linear. I.e. Mid greys should be about mid grey, you can see & store a lot of detail in shadow areas etc. Itâs just about understanding what your data is, and what you are doing when viewing it.
The whole thing about setting a standard between programs and hardware (monitors, digital cameras, printers, scanners) so that we are all dealing with essentially similar images, is known as sRGB colour space. Most 8-bit images are presumed to be stored in this space, so if you had an image without an embedded colour profile, you could assume sRGB and it should be pretty similar across platforms.
I think Iâm more clear on what you are saying now. Yep, it makes sense to try to obtain 2.2 for sRGB (as sRGB is standard 2.2) except for when using an older CRT or printing. So I guess if you define sRGB standard as 2.2 gamma across devices than you are absolutely correct - I was just reading into it wrong.
As for meeting floating point, thatâs just an option and a benefit depending on how you export. Alot of times my images are fine straight out of max burning LWF in aside from a few minor hue/saturation adjustments in post. I usually export to .EXR just to be safe as well but sometimes donât really need to touch it.
Some of the better 3d guys such as Nichols, Throb, or Morbid probably have a ton of other uses for these linear formats in post - but I doubt they bake in their solution like I do.
hi guys!
thanks a lot for comments/ help.
Maybe when i`ll got time, try make better LWF, but i think now, this is very hard, and sometime not helpfull ![]()
And here not LWF, but only small Vray camera Dof test:
cheers ![]()
Very nice, maybe it me but they look like minature apples - more like the size of large strawberries
gamma correction
Hereâs an extensive explanation by Master Zap as to âwhy is everything washed outâ with gamma correction
http://forums.cgsociety.org/showpost.php?p=4141325&postcount=37
hi:)
tom- thanks, apple are small becouse this is special kind of apples ![]()
rmeija- thanks a lot for link, very nice ![]()
