my first post, C&C are appreciated :)
This is my render of a retail shops. I notice behind the racking area is over bright, I try to reduce the Rectangular light multiplier but it couldnt fix it.
I’m using Vray version 1.05.03
my setting:
Image Sampler: Adaptive Subdivison, min -1, max 2; Threshold 0.1; Normals 0.05
DMC Sampler: Adaptive amount:0.95 ; Noise Threshold 0.01; Min Samples 16; Subdiv Mult 1
Color Mapping: Linear Multiply
DMC GI: Subdivs 10; secondary bounce 5
Irradiance Map: Min rate -3, Max rate 1
Hsph Subdivs 50; Samples 50
color threshold 0.2
Normal threshold 0.1
Dist thresold: 0.3
C & C are WELCOME. Thank You
Re: my first post, C&C are appreciated :slight_smile:
Could you upload a big image? Usually the Linear color mapping tends to burn out the area close to the light. You could use Reinhard, this option is “the best of two word”, if the burn value is close to one the result is more linear, if the burn value is close to 0 the result is more exponential. My recommendation is that you use Reinhard and reduce the burn value until you are happy with the result. The values could be from .85 until .35.
Best
Thanks mate. I will try reinhard. I wonder if i wanna render it into photo realistic, which setting should I tweak? Million Thanks. :slight_smile:
The most important part for a photo realistic look are the materials and illumination. Please post a big image to comment about these aspect. It’s very hard to see the image.
Best
