Hi ,
i finally found some free time to render a scene with corona.
this is my first render almost finished. need some advice for the pillow ,displacement setings and for the anti-aliasing at the window.
realy love rendering with corona
sorry for my english
Your pillow looks like made of aluminium, like these floating balloons. I think it would look good enough if you gave it the same shader your leather sofa has.
If you have the public alpha version it’s best NOT to use displacement.
About the antialiasing on the window frame - you could try carefully changing filtering settings or simply use darker sky so that contrast is lower.
Overall impression is pretty good. I would try changing wheel rubber to something less plastic looking (lower glossiness) and that carpet doesn’t look very real.
The lamp to the left needs more space.
This is pretty good but what with the AA ?
Check your wood’s uvw, fibers should be parallel to the longest length of your geometry.
Good ! you must take care more of some materials.
ps: is this an evermotion scene ?
yeap , its evermotion vol 27.
i did my best for the material but its my first final render with corona, i will try to make it better.
