Hi all, i’m from Ukraine!
Very liked your Corona, i worked with many renders, and i was surprised with the stability of your plugin. tnx for this
And my first work^
~10 min on intel i5 2500k
Wow!! really like the atmosphere and your image, may i know your settings if you dont mind, how did you make the fire is that a map with emission turn it on, or its just the map??? welcome to corona forum, greetings from mexico.
Thank you)
I turned on emissions in this map for good lighting.
Then i worked in photoshop to get the best result, because the fire was extremely contrast after render.
Path + HD
