I think i need some help… I`m not so sure in how to resize a texture… got the jpg and the maps for the bump and reflection… but… didn`t quite understand how to resize not in sketchup but in VRay… hel plz… here´s my piece of work, nothing too awesome… :-[ :-[
Shot at 2007-07-15
I`ll be posting more pics of this test room frequently… plz… give sugentions…
PD. how can i bump the texture but… less? like really subtle…
I´ve made some cool effects… this is the raw render from the vray…
Sugestions?
Re: My firts renderings using this software… sugestions plz…
Jeag
Nice first renders, and you seem to have got bump maps sorted.
If you need to reduce the amount of bump, then just reduce the multiplier in the bump texture editor for the particular material, e.g. try say 0.5 instead of 1.
Thats an interesting texture on the back wall. Is that a deliberate texture on the window wall or are they reflections?
Are you going to add windows and some depth to the outside wall?
You can also add some softness to the shadows by increasing the sun size multiplier to say 10 or 15. If you are using the physical sun this will soften the shadows. Here is a link to more sun info http://www.spot3d.com/vray/help/150R1/vraysun\_sky\_param.htm
tHE TEXTURE ON THE BACK WALL (THE ONE WITH THE “WINDOW”) IS DELIBERATED… iTS A TEXTURE MAP I GOT FORM ARROWAY… THOSE DUDES GIVE U THE TEXTURE BUMP AND REFLECTION MAP… TOO EASY… THOSE DUDES MAKE TEXTURES FOR MAXWELL… BUT I USE THEM FOR VRAY AND U GET GOOD RESULTS…
