My last Render
My last render
I like the red color on the walls. The only weakness of Enscape that still appears today is the shadow transparency setting.
There is no control so that the shadows such as those near the lamp, near the sofa are not too black.
In the meantime, to set it, you need to pay attention to the exposure settings. Check the light view mode. You adjust it by feeling, so that the dark area will not appear too clearly. You can.
In this particular case, it looks like the hard shadows are caused by the lamp not letting light trough.
One approach that comes to mind addressing this, would be to apply a cutout texture to the outside textile material, in addition to setting the material’s type on both faces of the lamp to foliage.
