hope you like it guys
thanks and regards
JDS
________________________
Re: my latest work for a friend interior living rm.
simply amazing…from sketch to photo finish!!!..i love the carpet and the curtain…hope i can do that to…he.he.he… ;)…
alq…
Jeff
Congratulations! superb work, simply amazing. Technique is very impressive.
How have you matched the vray with the sketchup? Lots of people struggle to get this effect.
Maybe the sky through the window could be a little brighter?
Very professional.
Thanks for sharing.
Regards
David
thanks david
i done it in ps using free transform and opacity to make it exact
How are designed the curtains with sketchup? What is a tool to make the cloth and wrinkles and the airwaves in curtains?
Thanks for the lesson!!!
and sorry for my english …i use a google translate ![]()
Hi guys,
just a quick tip. In order to match the view you have in sketchup and render that exact view in vray, all you have to do is go check what the values are when you export a simple 2d graphic (this will depend on your monitor´s size and also on the settings you have in sketchup, whether it´s fully open or if it´s reduced on screen) and then just write or remember those settings which could be something like 1000 wide and 728 high or something like that. Adjust the “width” setting in sketchup export olptions to what you would like the final vray render to be and check what it says in the “height” slot. For example if you want your final resolution to be 2000 pixels wide in vray, then write that number and you´ll get the height number to something close to 1400 or something like that. Then the numbers you get, just write them in the output settings in vray options.
Note: in order to make it match perfectly, the lens setting must be the same and also, the ratio must be set to “unlocked” in vray.
- Franklin Munoz
tips for the curtain pls…
HI! AMAZING IMAGES. Can you tell me where did yo get the 3D model of that curtais? It will be great if you can send it to me. Thanks
Santos, any trick, tip or how to do tool very useful to create curtains with sketchup. thanks
Calderon, if I find how to do it, please, send me. I hope that you too, to see if we get some curtains with Sketchup
The only thing I have achieved is this.
woooooooooooow…! Simply wonderful…! ![]()
sorry ive been too bc i left uae for 3days thats why i have no response to your questions guys… the curtain is a 3ds from max… you can download it from www.archidom.net all models are in this site hope i helped you guys… thanks for the comments
