my new animation with vantage
hello guys, this is my new work
There are some good ideas, like the split screens, but as a general constructive critique I would suggest working on the camera moves and transitions.
Ideally imo there needs to be a ‘flow’ to the piece, meaning that, for example, if camera A transitions to Camera B, then Cam B moves in a similar
direction to Cam A to create continuity. Another example is a panning exterior shot being followed by an interior shot that picks up its motion from where the exterior
left off, if you understand my meaning.
So the general idea is that each shot is a continuation of the previous, rather than each being a separate shot with the same curve.
Fade transitions as well as cuts can be used to mark points where there are distinct changes.
I picked up much of this stuff from some great pro camera people and editors, so thanks to them for that :slight_smile:
thank for your comment :stuck_out_tongue:
Hi yones,
Really good video, put me in a calm and happy mood, also good choice for the sounds.
Did you use Forest Color texture for your vegetations?
Congrats and keep up the good work.
Cheers,
Vladislav
Thank you, @Vladislav_Vulchev
no, I didn’t use Forest Color texture.
HI yones,
Very nice video! Can you please share with us what were the render settings that you used, how much time it took to render out, the hardware you used and did you had any major difficulties during the process?
Alexander
Thank you @Alexander.Atanasov
all setting has defaulted, just I change the sample in render dialogue from 100 to 200. each shot took 5 seconds for rendering in full HD mode. and I have RTX3090 24G.
I really enjoy working with vantage and it’s an amazing product.
just think need more samples especially in dark areas because of some flickering
and these are some still images
and some more
Very cool…What were your render times per sequence and what settings did you use for your output?
