Quite stunning. Great work! ![]()
Wow very nice image ![]()
Thank you for the positive appreciation of my work !!! Actually, we should thank you for such magic software !!! We are waiting for the latest and most necessary solutions from your team. !!! We hope that the current situation in the world can not stop you from making progress in your work
These look great! Could you perhaps share a screengrab of your lighting setup? I’m very curious to see how you lit the space (using point lights? or planes? etc)
Thanks for taking the time and assembling this! So you’re using spot lights at the actual location of the light fixtures + a self illuminating material for the cove light? No helper (‘fake’) fill lights or anything?
Really impressive results. Out of curiosity, how long would you say you spend on tweaking the lighting?
Actually, yes, I’m trying to install the lighting points in a position where they have to be according to the project , because I try to present my clients the scene as close as possible to the future result . I believe that it is logical to create an adequate perception of reality for all project participants . Not only for the client, but first and foremost for me , as well as for technical project participants / electricians, furniture makers, finishers and painters /
But if you look carefully, you will see some additional fake lighting elements at screenshot !! ![]()
As for the time spent on installing and adjusting the lighting points, I won’t say for sure, because I work simultaneously on different projects with different settings and come back to the light settings in a particular project sometimes in a few days or weeks !! But I can say that ENSCAPE saved a lot of time for me, including thanks to the not very, but still quite acceptable lighting settings system !!! I hope I was able to satisfy you with my answers?
Thanks for your time! very helpful.
how you make the stone texture/modelin on the wall and column ?
…thanks a lot for this detailed breakdown of your lighting :thumbup: :thumbup: - yes, Pieter above is right: such posts are really helpful !!!
@ART_ZAM thank you very much for this usefull information.
Ok , take it and use !!!
