My second project finished. Please take a look!!!
Hi! Well this is my last scene made in max 6.0 with V-Ray. I tryed to make it real and I think I’m getting close :smile: . Send critics and cments please, I need some tips.
Sorry about my bad english.
I quite like the lighting - good contrast, you need to tile the textures on your fabrics I think, at least 5 or 6 times. with more work this will look good!
I agree w/ the fabrics. Also, the bed length looks a little small for a normal (5’5") person.
The light above the beed looks strange as well, not only is the color pure white, a real light bulb or tube wouldbt be a perfect rectangle like that.
I love the curtains, but there is a problem with them, it looks as though they themselves arent casting shadows, w/ the sunlight at the angle that it is the folds in the fabric would alter the shadows.
Other then those things it looks nice.
I think the shadows are okay. It happens because the window frame that cast shadow in the curtain
Hi marcioczar !
Both images are a bit dark, I suppose you use linear color mapping.
If it is the case try to play with Hsv and you will get signifcant change…
For example try: dark multiplier 2.0
                         white multiplier 1.0
:slight_smile:
Bye !
Very nice,
and lovely curtains,
Are you using Area as the Anti-Aliasing filter? Try using Mitchell Netravali with blur 1.2 and ringing 1.5.
It gives sharper results.
Your’s.
The bed is too short and not wide enough, looks good though.
