My V-Ray concerns -- please tell me I'm wrong.
Well, like we discussed, I dug up the V-Ray 1.5 code and recompiled it so the truth shall be revealed soon :slight_smile:
wow…can’t wait to see the results :slight_smile:
Well I’m not quite sure but could this also be related to the BRDF you might be using? I tend to use GTR for everything nowadays but I experience A LOT more noise with this than with a blinn or ward.
I did make a post on here recently regarding scene optimisation and light noise and I just read from Vlado that the portals are causing a lot of noise - looking forward to the next release as the light render passes are almost unusable for me without heavy post work masking out the noise.
The visual below is an example of a scene where the use of GTR was out of the question. I used GTR as BRDF on every material but I had an enormous amount of noise (noise that even didn’t go away after hours of progressive rendering). Changing to Blinn/Ward cleaned the render up a lot better/faster.
There aren’t any light portals here only vray disc lights to light the scene.
Can you get me that scene? I want to try it with the new glossy Fresnel that I’m working on…
Yeah, it’s the same thing… I’m afraid you’ll have to redo your assets :slight_smile: In the meantime, the alSurface material will do pretty much the same thing, so you can use that one. It will be included in the next V-Ray service pack too.
Somehow I really doubt it…
Yep, the more scenes I have to play with, the better :slight_smile:
So I didn’t have the GTR setup anymore but I just did a quick conversion, and the result is as expected. See below. I don’t know but maybe I’m doing something wrong in terms of scene setup (lighting, exposure, color mapping). But after 20 minutes of progressive rendering and with active noise of 0.007 (30% left), it shouldn’t look like this I guess. Where can I drop the scene? It’s 230MB zipped.
Beauty:
Refl:
You can put it on wetransfer, or anywhere else like that, or you can email me to vlado@chaosgroup.com for the FTP info of our server.
Ok I’m sending it to your email with wetransfer, should be there in a few minutes.
I got it, thanks! Will post some images with the glossy Fresnel option when it’s in the builds.
I use GTX sparingly because of the noise on large surfaces and because of the white halo on grazing-angle reflections when using high glossiness.
Was there ever an update to this? When Bertand speaks, I listen.
For the GGX, yes - like I said we are working the implementation of glossy Fresnel. For the 1.5 vs 3.4 comparisons, so far in all my tests 3.4 is a lot faster with the same settings and for similar quality - I’m still working on some good comparison images to post. If you want to know something else, please clarify.
Yes, I meant GGX.
I’ve just come across this, and wondered if Vlado or Bertrand had considered the PC architecture Bertrand is using.
Over the past few years I have regularly use render nodes and occasionally a workstation similar to Bertrands machine, i.e. dual Xeon 32 threads, and although they work great in many occasions they have consistently given me problems in situations with high memory usage.
After doing some self initiated research into the cause a long time ago I resigned myself to the fact that this was possibly to due the motherboard architecture, in that only half of the memory is assigned directly to each CPU, to access the rest it has to cross the CPU bridge link… this is my suspected bottleneck and the cause of slowdowns.. and since I was out of time to investigate further I left it at that.
I now run watercooled i7s in a small but effective render farm now and I’m very happy with performance, and I’ve found that the latest Vray versions to be very good. When using a higher noise threshold, coupled with the denoiser and a good graphics card you can get amazingly quick results.
The issue in your case is the VRayLightMtl material in the light fixtures. There are lights there already, but they don’t cover the openings exactly and some GI rays manage to get inside and hit the bright light material.
I’ve seen this in a lot of scenes and in order to minimize this effect, for the next SP, I will be switching off the GI contribution of the VRayLightMtl material by default (although of course if can be enabled if one wants).
In any case, nothing to do with the GGX BRDF in this case.
The shared memory between CPUs is indeed a problem, but we also found a bottleneck in our code that could slow things down on many-core machines quite a bit. Although it typically started to show with 64 cores and more. It’s fixed for the SP, so hopefully things will run better on those machines.
