My version of Clay render
I was doing an experimentation with clay render and enhancing some bumps and showing sketchup lines. Here is my result.
Nice! I like the way it captures the feel of the space.
Very cool! The illumination and AO looks awesome!.
Thanks Fernando. I indeed use AO here.
Thank you Andy. I think I will dwell for the meantime exploring this type of output…will be doing some more testings.
Nomer - that looks very effective. Can you explain how you got the concentric waves in the pool. Last time I had water I used a procedural (purlin) texture to create the bump, but yours looks much better.
David
this is great, the AO and the water material on here is amazing, (water material been a lil tuff to achieve on my end)
David I used bump map only. here is the map. although the water doesnot act like the ripple in the map. but nevertheless i love this bump map., here is it.
HI Newgate. I made a tutorial here about water… I think with lil bit of experimentation you can achieve more than this. nomeradona ...: Tutorial: How to create Pool Water in Vray Sketchup
Nomer
Bump map and tut both excellent. A big thanks.
David
thank you nomer, that just solved my problem :slight_smile:
good to know that they are useful/
