When i try to render with perspective my wallpaper wont show up in the render.
Dear @victorgregers_hagethomsen , hello.
Could you share where exactly is this image added?
Is there a chance that it is a Texture added to a V-Ray Dome Light, which is set as Invisible?
Please see the example here.
Waiting for your answer.
TS
Okay, thanks, this was helpful.
This is a native Rhino functionality.
We could recommend using Background from V-Ray Frame Buffer, which sets the image in a way similar to your wanting, see here.
It could be easily changed even after a render is finished and is closer to a collage effect.
If you want to achieve also lighting contribution, you could add image to:
- Settings > Environment > Background and play around with options
- place is as a Texture in a V-Ray Dome Light
Please take a look and choose what is most suitable for your workflow.
Thanks Tsvetomira
ill give it a go
Best regards Victor Gregers
You are welcome!
“Settings > Environment > Background and play around with options”
Nice feature of V-ray: set texture Type “Environment” and Mapping “Screen”. This kind of setup works also for dome lights.
Yes, thanks, @Micha !
I will add changing the Shape to Sphere as a last step to your exact proposal if he wants to follow the wallpaper effect till the end.
