try make something on the table ![]()
caustic just to heavy to my pc so i turn it off
also the glass look weird to me ,near the table is realy bright…?
Make sure that bottom of the glass object does not intersects nor sits flat on the table. Lift it ever so slightly, otherwise you will have physically less correct result, or even artifacts. Also make sure to use absorption instead to give glass proper colour propagation.
[/quote]
[/quote]
Thx!
Looks better
I’ll continue my project - wip_v2
nothing is ready need modelling a lot when i have time ,no shader ready finish …at now try make some grading test ,this is the mood I want
