An early wip. I’m still having a little problem with those white dots appearing in the rendering. This is ca. 3hr+ rendering. I’m using “rawafake” sky and sun with manualy set color to 200,200,200 using any color(even just a little saturation) only with this setup I get low presence of those fireflies. Using latest legacy build…
I’ve simplified the material so it has only a diffuse color and a bit of reflection.. no masks no translucency, refraction… And I tried several different render settings nothing makes it go away. They’re less prominent if I use low sky and sun intensity values but still appear here and there plus the longer the render goes the more of them seem to appear. Turning image filtering off makes them smaller turning it on with default values(cone 1,5 + internal res 2) makes less of them appear but they’re bigger :D…
So either I’m doing something very wrong. Or there is a problem with reflection and lots of dense geometry…
Btw can’t run assert version of corona(max will crash, not able to load plugins)
ok, post the scene - Renderer for architectural visualization - Corona | Chaos
Ok, uploading now… Let me know if somethings missing. There is a max file and 2 proxies which goes into the Cscatterer and a ground texture… it’s 2013(64bit)
ok, mystery solved: you have perfect mirror reflections on the grass leaves. This combined with the geometric complexity of scattered grass causes random speckles to appear where the grass blade aligns to reflect the sunlight. You need to blur or remove the reflection on the leaves.
Did you use Progressive mode or VCM here ?
Keymaster : so the reflection with scattered objects and opacity are the problem ? will remove its reflection in my scene and see
Well… It does happen even at glossy values around 0,5 for refl. I have to blur the reflection so much that it really doesn’t matter if I use any…
So, there is no way to make corona sample away this kind of artifact?
It is not an artifact. What you are doing is scattering tiny mirrors on the ground - it makes sense you’ll see random bright flashes all over the ground where it aligns to reflect the sun. So you need to either dull the reflection, or make the sun not be visible in it (probably impossible with current set of fakes, but will be in the future)
I get it I get it!! Don’t yell at me :D:D:D lol… I was just thinking that reflection would be much less visible using very low values for sun (color and intensity) and yes, hiding sun worked only for direct visibility but is seen in reflection. Thanks for help with this
I’ll make some adjustments for the materials then…
That makes sense since there was larger amount of smaller bright spots without image filtering and less amount but bigger spots with 1,5px cone filter. However I partially solved the issue with very low glossiness values as well as reflections so it’s ok but in some cases it might be pretty tricky to correctly tonemap lightsources visible directly or in reflections to get rid of aliasing.
I’m thinking, how would you solve a situation like: night street view after rain with lots of light emiters and tons of wet reflective geometry in the background? I need to try this ![]()
DOF the shit outta it and apply some artsy bokeh ![]()
What a solution!!
You should add that at the end of some future manual “…And if anything else fails DOF the shit outta it and apply some artsy bokeh…”
Definitely… I don’t even know, is this an image sampling error in corona, or image filtering? Or does it need some advanced alien technology from this guy? https://www.youtube.com/watch?v=wkInPAWjtPg
I don’t, so good luck getting it “fixed” ;). The proper solution would be probably disabling the visibility of sun in reflections.
Ok, seriously now. This might be a big issue in animation of some complex environment. We have not seen a full featured CGI environment with all sorts of artificial lights to enhance the atmosphere during an animation with lots of moving objects etc and all extremely sharp in 1080p. If corona continues doing so well and have all the popular features as hair and sss and so on(Btw I can imagine some furry stuff:D having shader with sharp reflections where it could be pretty problematic to avoid this issue) it will face situations like this.
Cause if some popular studio decides to try corona out doing some crazy shit, then avoiding direct and in reflection visibility of lightsources because of some aliasing or image filtering issue is out of question. You can’t change the look of the scene in animation and tell the client it can’t be done this way. As a studio you would have to choose another renderer and your product reputation goes down.
And this is something you know of. How much can appear once it goes commercial what you don’t know about cause it has not been tested? You won’t know how and suddenly there will be tons of people arguing with you why the product they bought is not working as expected. This is not a missing feature you can make your future client aware that it does not have. How would you explain to them that the white overkill:D is normal and how would you make customer aware of this. Would you state this behavior in features category?
Like it or not, once you get this commercial you will be sooner or later forced by some client to make this go away cause money plays. Why not do it before it is commercial to save time for future not known issues you will face? I don’t know who do you want to aim your product at. As an individual you can live with this, not a really big problem. But as a studio with lots of bought licenses and some paid courses(big studios will gladly pay you to come there and teach their people how to use corona more effectively etc) you would be much less tolerant to stuff like this.
I wish you the best, don’t think of this as a complaint, I love corona it has massive potential. I don’t care, I haven’t paid for corona now and I don’t care how you do your stuff. But try statement “good luck fixing it” to someone who buys your product
good luck with that man:D
I agree with Lacilaci, hope the major issues will be fixed soon.
I’m planning to buy the final release of Corona or the beta stable one if it will be for sell, so guys i’m waiting for your big effort to improve and fix this baby and limit the fakes inside it, Good luck !
That was meant specifically for rawalanche, because he can be quite annoying when something is not done his way ;). Here is more part of the development team than a customer ;).
I already fixed that issue changing the materials… And unless those white spots on your trees and on the ground are some flowers, then you might have this problem aswell ![]()
