NaN
After some time I decided to try version 8.
But the first thing that is important for me is if the NaN bug is solved. Unfortunately, it is not. Every time there is a sky object in a complex scene with light material for seen, reflection and refraction…
NaN.c4d (548 KB)
Hi, thanks for letting us know. I can also confirm the NaN warning in this scene.
(Internal ID=816216411)
i also get NANS in latest v8 sadly (with hdri in sky obj and visibility buttons used)
hope this can be soon fixed, i cant use v8 atm therefore
Hi Stefan,
As mentioned in another thread, can you record a short video of this happening for me? Much appreciated :smiley:
not sure what the record might bring?
i press render, it prepares, then the Nan error comes up,
the scene is all white in render, sky black or visible(depends on scene)
no more is happening.
i use the visibility buttons in sky and hdri dome (hdri in sky obj)
edit:
here a screenshot, it should show all infos that can be seen visually:
error in c4d console is:
"2021/12/27 17:36:41 An internal error has occurred causing your image to contain NaN (Not a Number) value.
Please report the bug with the scene attached. We can fix these problems promptly if we have the scene where it happens"
somewhere here in the C4d forum i have read today that a v8 NaN bug is known with sky visibility settings? (regression bug that came back)
we are aware of a NaN caused by “visible in reflections” turned off and we are working on a fix.
Thanks,
Jan
thanks!
