Need Distributed Rendering Help
I’m trying to set up distributed rendering and can’t get it to work. I have backburner working just fine. Here is my system and what I’ve tried so far.
Client: Win Xp Pro, Viz 2005, Vray 1.47.03, Dual Xeon 3.2, 2GB Ram
Servers (10): Win 2000 Server, Viz 2005, Vray 1.47.03, Dual Opteron, 2GB Ram
I installed the same version of Viz and Vray on all computers.
I created a file called vrayspawner.ini (the online manual called it vrayspawer.ini, which I think is a misspelling, but I tried it with both file names present). In the .ini file I added the following text:
AppName=<C:\Program Files\Autodesk VIZ 2005\3dsviz.exe>
I double click on vrayspawner60.exe but nothing happens.
I copied a backburner .xml file into the Viz root directory and called it vraydummy60.xml and tried to execute vrayspawner60.exe again but nothing happens.
I opened vraydummy60.max in Viz and saved it out again. Still nothing works.
I’ve tried selecting Distributed Rendering in the system rollout. I can add the servers and resolve the address. When I render, only the Client’s buckets (0.0.0.0) render.
What am I doing wrong? Any help would be great.
Craig
Did you try the procedure I outlined in this post?
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=9201
czoog,
Thanks for your reply.
Yes, I followed your post, but it didn’t work for me. I am wondering about the part where you wrote “restart vraydummy60.exe” did you mean restart vrayspawner60.exe?
Craig
yeah, i ment spawner, sorry.
czoog,
What vray version are you using? 1.47.0360, 1.47.0350?
I read a post by Vlado (I think) that the new version of Vray doesn’t need to have spawner started. Did you have to start up spawner? Did you have to create a vraydummy60.xml file as outlined in the manual? Any other thoughts on what I might be doing wrong?
Thanks again.
Craig
