Need Help About Noise
Hi
I render This image on Default Settings with Corona Sun n Sky but after 6 hours still have Noise Please Help me about that Thanks
Its clear your lights are unbalanced.
Probably your middle curtain has some really bad settings. Try opening the window and render the same image with owerride material et to 160 white~
Test how will that work, if it will help try unhiding your curtain and exclude it in owerride then check if noise is back. If it is its you need to look at forum for curtains topic that was started already.
Thank you for your reply i will render again
It’s probably some basic mistake like solid glass in the window hole or no portals or strange curtain settings. Please read:
HOLY CRAP!.. thats some serious noise.
Check gamma, and double check glass material from windows and opening.
Seriously.. never seen that much noise here in the forum.
What did you put as lights?
there is no glass behind curtain i used DayLight with Corona Sun and skylight none and in HDRI map VrayHDRI SkyMap
Gamma Was 2.2
i think wall shader is the problem in your scene , you have a dark wall and also high light intensity . render your scene with override material (grey) and setup your light amount . if the problem was fixed then you can use a raiswitch material for your wall with a bright material in gi slot.
what is your curtain shader ? (did you use translucence for that ?)
