I could see a very nice photo on the internet, I woould like to reproduce in 3d. Well, I’ve never done any specific studio shot like you can see on this image, but it would be cool if I could reproduce something specific like shown on this image here:
Thank you very much for every little help and all your suggestions,
bernhard
Seems like a spherical light on each side judging by the reflections or possibly a white surface on either side of the phones with a light shining towards each - if you don’t point a light directly towards an object but instead aim it towards a white card that bounces light towards the object you get softer results.
that’s now pretty interesting… I’ve tried to get softer reflections, so i’ve positioned the lights against a plane, bouncing back from there to the object…
but you can clearly see a very hard reflection…
just a quick test render:
Also, if you’re trying to go the full photography route and avoid post effects… you could bounce the light off a plane, just make the plane big enough that it can capture the full falloff of the light… and make sure to turn your light invisible
Thank you for all your efforts, I really appreciate that.
I was looking at zulibans setup - and I think it’s very good, but I could not reach what I wanted. So I decided to make one more test.
As I said before, I don’t wanted to use any glossy effect in the material settings, instead of this, I wanted to find a way to get a nice and blurry light reflection on a pure high reflective chrome material.
Here is the result:
I’ve used 3 lightsources, white, blue, orange in a sphere.
The lights are planes and targeting against the inner-surface of the sphere, so the light bounces from that wall back to the object.
Hmm, well, indirect light source
ok, now I will try some other material tests, but I am not really sure if that will fit to the photo I’ve posted above.
thx for every little help
I really appreciate that much,
bernhard
okay if you want to get a softer result in that teapot, put a white plane in the position of the light, then put your light in between the teapot and the plane. Point your light towards the plane so that you get a hotspot and a bit of falloff on the centre of the plane - the teapot will reflect the hot centre of the light gradually fading off to the edges of the plane and it’ll also bounce light back towards the teapot.
