NEED HELP - Vray for Sketchup 2022 - Chaos Cosmos - "Chaos Cosmos Browser failed to load"
“Chaos Cosmos Browser failed to load”
I installed VRAY 6 for Sketchup 2022 on my Macbook. But I can’t start Cosmos, you can see the error page on attached screenshot.
Hey there,
Can you please create an issue here and attach your cb.log and config.json files, located at /Library/ChaosGroup/ChaosCosmos ?​​
Thanks for the Information. Im using MacBook. There I can only find the logfile but no config.json file ?
Hm, then when you create the issue from the link above, can you please provide the install.log located in /Applications/ChaosGroup/ChaosCosmos/uninstall ?
Also, can you please open Terminal app and execute the following:
/Applications/ChaosGroup/ChaosCosmos/cbservice.bin genconfig
See if this creates a config.json file in the directory I posted in my previous reply.
Then you can run /Applications/ChaosGroup/ChaosCosmos/cbservice.bin in the terminal and check if Cosmos Browser works.
Wow - worked !!!
Glad to hear. Still, we would be thankful if you send us the logs/configs in an issue created from the link in my 1st reply, so we can investigate what went wrong with the installation. Thank you!
