I’m doing a animation of a card that shall be imported to Flash with PNG’s. The background needs to be a vectorgradient so the plane where the card stands have to be transparent in the PNG file.
The obvious solution would be to use a matte material on the plane where the card stands, but in addition to the shadow, I want the floor reflecton to show up in the PNG. How do I do that?
The image below shows what I want to do… The green areas need to be transparent…
as far as I know the reflection does not effect the alpha channel. not sure if this is an option for you but if you render it over green like in your image you could always key it in after effect and save out the png sequence from there. I’m not sure how clean it would be but it would give you an alpha of the reflection.
I’m sure other people will have suggestions for this one.
RErender: Good idea, but how can I get the plane 100% white without “overexposing” the reflections and shadow? any other way than turning up the lights?
vance3d: hmm… could do it on a bluescreen, but I think it will be a bit “dirty” in the quality Any other solutions besides matte object?
I guess you could always just run 2 passes if its quick to render.
One to get your wanted alha and one to get the reflection channel.
You could black and white reflection pass then stick it and the alpha together in PS and use that as the alpha on the normal RGB render?
Probabaly wouldnt be all that accurate tho.. but might work.
Or what RErender said would work pretty well too I think.
