So this is my first test. Its directly converted from vray to corona.
My objective is to compare render times to see if I can get corona in production pipeline here at the office.
I used PT - HD, standard settings and let it cook for about 3h:13min in a dual xeon. This is what I got… plenty of noise.
3 hours of processing aren’t enough to clean a scene of this type ?
Mind you that this is an optimal interior (the back and side of the room are windows) and its lit only with a HDRI.
something is definitely wrong. Are you using default settings (PT samples, lights multiplier)? Can you printscreen the stats window (you activate in in VFB) after some time (~10 passes) when rendering?
I’m using it with gamma boosted to 0.75. And I’m running it from a colorcorrection map and vrayhdri map.
Due this setup never gave me problems in the past I never thought that could be cause.
I’ll guess that I can start by trying using a cleaner solution.
I will report tomorrow with my findings.
Mean while if you find something awkward with the settings please alert me.
I tried to swap hdri for coronasky lightning went worse as expected… similar behaviour maybe a little less grainy.
Then I turned off the glass (a box with a material applied with refraction onesided (box)) i got acceptable noise levels by the 327 pass… That would mean more or less a render of 6 hours
Better but I think that for this kind of scene the render times are still to high and with allot of conditions (glass turned off, coronasky)
Hello Polymax, thank you but unfortunately I can’t post the scene.
The glass in hybrid certainly helped thanks for the reminder Rawalanche .
3 hours render, PT-HD standard settings, noise is somewhat acceptable, not perfect but acceptable. Can it be optimized ?
ANother question:
Corona framebuffer is 32 bits right ? I saved the image in exr and I felt that in a way I didn’t got that dynamic range that I usually do.
It could be for the position of hdri but when I played with curves I couldn’t boost mids like usually.
I didn’t compressed highlights in corona post processing to keep max color info but I used exposure compensation to correctly expose the scene.
Well it’s getting rare the works that have manageable deadlines. Usually we have 1 day for 1 image. So if we have to do 4 images, we have 4 days.
That’s why I’m trying to migrate to corona. Less settings to mess about, less setting tests to optimize scenes, more time to work on what it real matters.
Keymaster:
Not using portal lights .
Here it is the post-processing settings screen.
I had to use -4 exposure compensation to correctly expose the image. Should I use it only to preview and when saving the image revert back to 0 ?
