I always have doubts about it. Should I add backgrounds in postproduction or directly render them in the scene???
In the scene below, I first tried rendering some grass in the front of the house and a background image as a plane with an emission layer.
Unfortunatelly, the grass got too bright, because of the high GI used to render the internal scene. And the background image got washed out.
So I tried what most people do: render without background, and turn on the alpha layer… so I can add the background in photoshop.
Problem is… its quite difficult to add a background in photoshop in a scene with many reflections and the like.In this image, there are reflections in the floor, reflections in the mirror on the left (not only would I need to properly place the image there but also place it “behind” the curtains in the reflection! There is also reflection on the glass table and on the luminaire… the ideal solution would be to be able to add an image as a background on VRAY, without needing the image to be a 360 degree panoramic to add under the spherical method…
So, how do you deal with the background problem???
Re: Need tips on background: postproduction or render?
Hey there,
you have different options to get this problem in line:
You could:
- turn down the multiplier of the outside image maps.
- increase indoor lighting and balance GI to fit scene.
- use physical camera and sun, render three images with different exposure values (-1, 0, +1) and put it together as HDRI in Photoshop (just like photographers would wo in the exact same situation)
…that’s what comes to my mind right now, possibly there’s 100 ways more
Hope it helps!
it just sucks that each time I want to test a different setting, I have to wait over 25 minutes for it to START to render… even after using the “Remove CG Materials” plugin… all this time to start rendering is really making my life difficult.
yes, 1.05.30 (I am afraid to change to the new version, too many people complaining of bugs and there is even a sticky topic about reverting back to 1.05.30!)
the model is 78 megabytes
602k edges
258k faces
141 component instances
Or you could sign up for the beta and get a copy of the latest beta. But if you do, remember to back up your models before loading them, it is after all a beta.
