How set camer to get elevation of building ? (not only sketchup , but to make render )
Re: Need urgent help ! How to set camer
turn your physical camera off. set your default camera to “standard”. If you want to show true shadows, turn on your default lights but adjust the background color intensity (.2 has worked for me).
Note: both skylight and background are set to none…you’ll get a white sky.
that doesnt work !! still make perspective and i already try this method ![]()
Ok i know why itd doesnt work i have CRAPY rc1 version
thats all
great… it works on 1.00.
You’re trying for a parallel projection…correct. Best way is to set the field of view very narrow, and that will make it look like an elevation.
Tes i tried this but you need to set camera far from object and this doesnt work for big things as i see , i had problems with that.
But , as i wrote versione RC1 has a bug and in 1.00 you can make elevetion without problem.
