Need Your Help
Hi everyone!
Blotches…in colour this time…
Have downloaded the material update from vray, new updated vray
version (n), everything has a thickness to it, vray light has sub.div 8,
no standard max raytracing
hmm, I’m totally going crazy - help, please - anyone…
You can view the render here:
http://vr.reaperfields.com/images2/b.jpg
You see that on the floor, on the furniture, behind the sofa and
the orange on the cash desk…Whats going on?
Cheers
Anders
Wat are your GI settings?
Cheers for answering Vlado!
My Settings:
First Bounce Min Rate -3, Max Rate-2
0.75
HSph
40
Interp Sample
40
Second Bounce
0.75
Global photon map
Bounces
30
Interp sample
30
Search dist
100
Max photons
30
Multiplier
1
Max density
40
Raytrace Threshold
2
Ratrace bounces
10
Best
Anders
Photons
Hello again…
Now I have turned off the Photons and it renders without
blotches. Is that a common problem - that Vray light and
photons clash? Are my Photon settings madly wrong?
/A
I had a similar problema little while ago, the fix was checking your materials and making sure you have no raytrace materials.
Chris Jackson
cj@arcad.co.nz
www.arcad.co.nz
number of bounces and retrace bounces must be the same,
maybe also you check the “check sample visibility” in the advanced imap rollout. I think this causing one of the spots where surface meets.
Cheers!!!
Will try that now!!!
:cry:
Tried what you said, doesnt work.
Cheers for aswering!!
Anders
check your email.
Maybe it could be a caustic problem? try to turn off G/R caustic for objects in vray object properties
