HI!!! Can anyone suggest settings for a neon light material???
I’ve been trying to make a Corona Material for a lit acrylic sign like this: I’ve tried using a translucent material with a light behind it, a lit material, and even scattering but I just can’t seem to get the look right. Does anyone have any...
Not same but maybe it helps.
Excited Gas. With Fluorescent lights, we’ve been experimenting with fall off on the opposite axis. It seems to work well on neon also.
sylphx
June 20, 2016, 8:24pm
4
Here is what I came up with.
It’s actually two objects a larger spline with a shell modifier applied to it for the glass.
then the neon material, a corona light material with a fall off map in the opacity slow.
Thanks for your example. The glass shell, is sometimes a colored glass. There’s where the volume absorption comes in.
Here. Glass with shell from above. Light mtl with no emition and faloff inside. + pp in arion FX for glow.
maru
June 21, 2016, 1:46pm
7
Where’s the “like” button?
