Nested blend + Bump Problems
Hi.
I´m having this problem and can´t figure how to solve it.
If i use any bump/normal/displace in one of the blend materials, the bump/normal/displace effect applies to all the layers. So i can´t blend some materials. Sometimes i want to generate gloss or sparks using bump and add a mirror layer without bump. Works fine in Vray, i´m doing something wrong?.
Some examples. I´m using the ball from http://www.grantwarwick.net/:
If i disable bump/normal it blends ok but i loose the spark effect:
I´m not trying to compare vray and Corona, Vray its just mi reference engine. I love Corona.
ok, So there is no way to do it at the moment?.
Thx for your reply
