Hi!, Im currently using Forest Pro v. 4.1.6 in 3ds Max 2013. Im trying to render a scene with nested forests to distribute over a grass surface. When I try to render nested forests with simple objects (basic spheres) they render correctly. When I try to use grass models in the same scene they wont render.. If I change to Vray it will render.. is there any solution for this? thank you for your time
Just wrote to the iToo Software team and they offered a solution to this. Just needs changing in the inner Forest object: Display->Render->Mode from Automatic to Meshes. That solves the issue. Hope this helps to more people in the same situation.
