However, this is what I try to avoid as, if doing that, I’ll have to assign object IDs on a per-object basis for more than hundreds of objects. That’s really inefficient. I can opt to use material ID for setting up mattes, but still a finer control is desired when I need to separate the mattes for groups of objects with the same material assigned.
