Because vray has files in the max install dir, its not possible to simply drop the files into network plugin dir. It has to be installed, at least as far as I know. Just curious how people handle large network deployment.
as long as your plugins.ini file points to the plugins you should be fine i think
I kill the backburner manager wait for a bit and run a bat file that copies to the correct folders kinda pain to create the bat with all the systems listed but after that it is easy to keep up to date, that is, as long as IT lets me know when computer names change or are added..
