Hello
we are recently experimenting network install for Vray (6.10.09 for 3dsmax2023)
- installing vray a workstation
- grabing the folder C:\ProgramData\Autodesk\ApplicationPlugins\VRay3ds Max2023
- copy on the network
- add environnement variable on workstations : ADSK_APPLICATION_PLUGINS = \\network_path\Vray3dsmax\6.10.09\
This seems to work great
We still need to stress test with the renderfarm just to verify that the network performance are good.
But we have a little bug : the preview shader in the Slate Material Editor seems to be broken.
It work fine if in install vray ‘the old way’
Nerwork install
Standard install :
Any idea ? Can someone reproduce this ?
-p-
