Hi! I have 3 machine, they are all the same, all with 8 cores each one and XP64 and 8GB of RAM.
Some machines are not rendering using all the cores, is like one machine is using all the 8 cores, but the other two are using only one or two. This is rendering using Backburner. IS there a limit on the amount of cores one can use with Vray rendering using Backburner? Or is it another problem what I facing here?
To make it more interesting, I’m opening the same MAX file on each one of the machines independently in MAX, and rendering same frame, 1 machine render it using all the cores and put the machine to 100% CPU usage, while the other two machines only put the CPU usage to 50% or lower… the machines are exact clones…
victorwol, i have same problem with same configuration - 8 cores, 8gbram xp64
Did you resolved your problem?
could you write about solution or root of problem?
Mmmm… don’t remember… Will take a look tomorrow. This happens to you on all the computers where you render or just in one? My problem was all the PCs where rendering at full speed except one going 4 times slower. But any other Vray scene render at full speed on that same machine.
I’m afraid the problem is MAX not Vray, I’m rendering a project with Final Render, and have the same problem, one machine goes at half speed… have very simple materials, only weird thing I have is an audio track on the animation editor… have to chech if that afect it in some way.
