Network render vraymap calculation
I want to create an ‘incremental add’ vraymap solution for every 25th frame of a sequence.
I don’t want to use my machine to create this solution as I will be working on other things. Instead, I want to get one of my render slaves to work on this.
However, if I send the job to the render queue, all my slaves will try and render its frames and the solution will likely be lost.
Is it possible to send this job to just one of my slaves? When I deselect ‘use all slaves’ in the render dialogue box, ‘submit’ is greyed out.
Is there a better way to get a render slave to work out a solution for an animation path?
After deselecting “use all slaves” you need to select just one server in the window on the right.
ah - silly me
(cheeks going a slight shade of pink!)
:sweat_smile:
