Network rendering error
Did any of you seen this error before?
This error started when we went to max 2016 from 2012.
Thank you,
Hi, for now, the only known solution is to prevent the info center from running…
https://coronarenderer.freshdesk.com/support/solutions/articles/5000660205
Thank you,
Hallo ,i have that Error to, prevent the info center from running solution don’t work for me. Is there any other solution ?
Well, if you are getting an error which says “Autodesk InfoCenter has stopped working”, then the info center was not prevented from running. Or maybe I do not understand something.
Halo, faund solution for me . I am uninstall Auodesk Aplication Manager . That’s work for me.
