Network rendering speed/network storage
I need help or advice, how to properly set up network rendering with corona+3dsmax+backburner. I’m doing this for several years now, but now, i have 1 workstations and 3 render slaves, and it semms, that the network speed affects the rendering speed. My rendering speeds are inconsistent. Sometimes, my Threadripper 3970x renders the animation with the same speed, as my Ryzen 3950x - which could not be the case, since the threadripper is basically twice so fast. However often this is the case.
I’m starting to think, this is because all the assets are stored on the workstation. The asset paths are all network path, and the slaves are getting all the assets during rendering from the workstation. I have a standard gigabit ethernet network.
What do you think, could this be the reason, why the threadripper 3970x is not rendering faster, than the ryzen 3950x? I mean, that, the slaves are not gettig all the assets fast enough during the rendering? I’m rendering very heavy scenes, with lots of proxies, large textures, etc.
If I would use a NAS, would it help? Does any of you have a NAS properly set up for this usage?
Thanks!
