Hi there,
I have a strange behavior with rendering SuperSpray particle over backburner.
If the “check for missing files” box is checked, the particles are not visible in frames from the renderfarm. If I render the same file on the local workstation, everything is fine …
Is it bug or a feature?
Greets
BLADE
Some infos: winXP 32, max2008, Vray 1.5 SP2, rendeing in fields
