Network Rendering with Backburner & DR
Could anyone offer some guidelines on rendering singleframe from multiple scenes using Backburner to manage the renderqueu and DR
to render?
I’ve tried this and get an error from the manager…
The maxfiles are setup with precalculated IR maps, rendering “from file”. The IR file is on network drive. All scenes render perfectly using just DR and leaving Backburner out of it.
It seems as if Backburner won’t acknowledge a file the uses DR to render the image.
If anybody has been wrestling this, or even better has come up with a solution, that doesn’t require special Maxscripting, help is much appreciated.
You should only use one or the other, I dont think DR and Backburner were ment to be used together.
-dave
