ok so i have a stupidly non-standard network setup here. stupid because networking isnt something i know much about, so i should have just stuck with the standard setup..
so, i have 3 machines. main workstation is connected to router via ethernet (gigabit port on machine, but router is only 100 megabit. )
in main machine i have a dual port 10gb infiniband card.
until recently i had a single second machine connected via infiniband to the main machine..
worked fine.
ive now added a second machine, connected via infiniband to the second port on the main machine.
this means of course, in my setup i have 3 subnets. one router to main machine, one main machine to second machine, and one, main machine to third machine.
issue is, the third machine. since adding it, i can remote desktop to it no problem, but i cannot access any of the shared drives on the main machine. i can see the main machine in the network, but if i double click it, or attempt to access the shared drives, it says cannot access this machine blah blah.
when i run the troubleshooter it says my third machine has an invalid ip setup. quite how i can remote desktop into it in this case is a mystery to me.
i run the troubleshooter repair, but it doesnt fix it.
now, if this is an infiniband issue, i dont expect to get much help, its so obscure to use it on windows, (but its cheap and damn fast)
however if its just a case of setting my ip addresses, subnet masks and default gateways correctly, maybe someone can advise.. i have no idea what to use, specifically for subnet masks and default gateway, dns etc.etc.. its all nonsense to me. i usually just let it do auto settings.
