new at Vray
first post with vray, model is from Zirak at www.suplugins.com
changed some settings and had a go
what do you guys think about the lighting levels and the reflective floor?
Re: new at Vray
That model seems awfully familiar to me… ::slight_smile:
Re: new at Vray
zirak borrowed it from biebel… ::slight_smile:
seen the post title!
Re: new at Vray
Hi Madmax,
I think this is quite a good rendering.
I would change the floor material though as it is a bit too reflective.
Have you thought of using a ‘white’ for the walls that has smaller RGB values? e.g 220,220,220.
Cheers,
Biebel
Re: new at Vray
agreed… the floor is too reflective..
btw its good…
i wish i could do something like that… it will took me ages to learn it by myself..
:frowning: :slight_smile:
Re: new at Vray
Biebel
Thanks for the tip…I will try this
Re: new at Vray
Biebel, I thought you knew that Zirak had done a model similar to yours…if not sorry for the similarity…we are all trying to achieve the quality that you produce with your renders
Re: new at Vray
2nd attempt, used Biebel’s suggestion for the wall (RGB color white)
i think it looks better
Re: new at Vray
it does look better but maybe you should pu something in the scene, some furniture maybe.
Re: new at Vray
Gligorov
Where can i find cool furniture to put in the scene?
Re: new at Vray
o how i love th effect and contrast of Guernica on the wall.
