Anyone mind looking over these spec for me? It’s for my primary workstation. I am thinking a Xeon build would be wise for my main computer as I’ve found them to be quite robust. This will give me 56 buckets.
Asus Z10PE-UD16 WS mobo https://www.asus.com/us/Motherboards/Z10PED16_WS/
2x Intel Xeon E5-2680v4 2.4GHz 14cores http://ark.intel.com/products/91754/Intel-Xeon-Processor-E5-2680-v4-35M-Cache-2_40-GHz
128 or 256GB RDIMM ECC DDR4 2400MHz - the quantity will most likely be determined by cost - I can use the approved RAM list that is published by Asus but I’m a little unsure whether I can I fill 8 of the 16 slots with 128GB of 2400MHz without sacrificing any bandwidth or something else?
GTX 1080ti GPU - I’m gonna get one anyway despite it not being on the approved list http://dlcdnet.asus.com/pub/ASUS/mb/Socket2011-R3/Z10PE-D16_WS/QVL/Z10PE-D16_WS_Device_QVL_13022017.pdf?_ga=2.243880711.349393638.1494544125-1879551656.1492213703
Samsung 960 EVO 500GB m2 SSD (not on the approved list but very quick) http://www.samsung.com/us/computing/memory-storage/solid-state-drives/ssd-960-evo-m-2-500gb-mz-v6e500bw/
Corsair HX1000i PSU (in case I get another GPU) http://www.corsair.com/en-eu/hxi-series-hx1000i-high-performance-atx-power-supply-1000-watt-80-plus-platinum-certified-psu
Coolermaster Seidon 120V 86.2 CFM Liquid CPU cooler x 2 http://www.coolermaster.com/cooling/seidon/seidon-120v/
The reasoning for the large amount of memory is based on the amount I tended to use when using a single Xeon setup with 128GB RAM. I tend to multitask, and don’t always want to close PS if I’ve got some large comps open.
The memory speeds are what confuses me the most. I read here but this is outdated: https://www.kingston.com/en/business/server_solutions/best_practices/maximizing_performance
I’m using a NAS for storage. Could possibly RAID the primary SSD or have a separate one for scratch. I have a 1TB WD Black HDD that I will utilize too.
