New build available - 1.09.03e
Currently only the Advanced version is updated, the rest are coming soon. This version of VRay is in the form of an installation .exe file instead of a .zip file.
Build 1.09.03e:
(*) The VRayLight could crash if the user right-clicks while creating it.
(*) Saved irradiance maps were not always loaded properly (bug in 1.09.03a-d) causing excessive render times.
(*) VRay could crash sometimes while calculating irradiance maps (bug in 1.09.03a-d).
(*) VRay could crash sometimes with VRayLights (bug in 1.09.03a-d).
(*) Files created with the beta versions of VRay (0.5x.xx) will not load at all from this build onward.
(*) All of the renderer parameters are exposed through MaxScript (in 3dsmax 5.x). Note that this may cause some incompatibilities with existing MaxScripts - they will need to be updated.
(*) Added MaxScript methods for loading/saving irradiance and photon maps.
(*) The Bake3D plug-in file is named differently for each 3dsmax version (Bake3d31.dlu, Bake3d40.dlu and Bake3d50.dlu respectively).
Fixed the netrender slowdown bug that was killing me last week. :smile:
And it has an installer. :smile:
Vlado - You have made an overworked lad very happy. I’m all choked up. :wink:
:smile: :smile:
Re: New build available - 1.09.03e
Vlado, does the EXE detect which DLL’s are on the machine and remove any unnecessary ones? I had a terrible time weeding through the renamed DLL’s when you changed the “40” to “50” in the dll names. Not a problem for one machine, but with 5 advanced licenses, and 20 render nodes, it became a bit time consuming.
Are you referring to pre-release Vray 1.0 files?
:frowning: :frowning: Why i cant see the new build in the Download section??
there is not the download link… :cry:
Could you please offer also a version without installer!
I have to start it on all render slaves, but just want to drop the files in the root files! It’s much easier!
robert
i second that :slight_smile:
I third it! :slight_smile:
Thank you so much for this!!! No I can finish my script :slight_smile:
-bill
YES, script for irradiance map…YES !!!![/quote]
