New CPU, Motherboard and RAM
Hi. i have 3000€ to spend on a cpu. motherboard and ram, should i go for a amd? or intel? if so witch CPU should i select? i only have 3000€ for the 3 items.
thank you
We are also going to build up new workstations, heres our setup (Without Ram, Cooling, Power and Case:
Price Range will be 2500-2900 € when its build up.
CPU: AMD 7950x
Motherboard: ASUS ProArt X670E (If you work with a 10Gbit Network)
DDR5:
Graphics: RX 6800 XT
Samsung M2 Pro 1TB
See Processor Benchmark
You also can look around for an Intel 13900ks CPU.
Greetings
thank you for your help, do you have idea which ram should i select to work with amd? i want to put 128gb of ram but i heard amd needs some specific ram, is that true? thanks!
it has to be DDR5 RAM.
here so far our setup
AM5 ATX Asus ProArt X670-E DDR5/M.2/1xRJ45 10Gbit
AMD Ryzen9 7950X AM5 X16 4.7Ghz Box 12x768KB/12MB/64MB
Corsair Hydro H150i RGB Elite 3
DDR5 64GB 5600Mhz CL36 G.Skill RS5K Kitof2
2000GB M.2 NVMeG4 7450/6900MB Samsung 990 PRO
16GB PCI-E AMD RX6800XT Asus TUF OC 3xDP/1xHDMI
BeQuiet P4/P8
BE Quiet StraightPower11 1200W 80+ Platinum
cheers
