would it be possible to have the new edgemap also work with closed surfaces/volumes, and not only planes ?
thanks
Why don’t you consider using a round edge map for closed objects? Could you provide a specific use case scenario where an edge map would be more effective?
Also consider using:
Corona AO - Corona for 3ds Max
Corona Curvature - Corona for 3ds Max
Corona Distance - Corona for 3ds Max
Corona Wire - Corona for 3ds Max
The Edge map was added specifically to cover the use case the other maps couldn’t - coloring the boundaries of non-solid objects.
