Ahah, sneaky! With integers? ^^
Jokes aside, if we do not get votes *per feature* we are not going to be able to prioritise development based on *your* choices; rather once again *we* are the ones to have to choose priorities.
Normal Map Auto color space in MultisubTex - Hermit have shared an Script to change the color space to the vraybitmaps ont Multisub but this could be great to have it in the Normal Map or transfer automatically while conecting a normal map
Convert CoronaDisplacementMod - Vray Converter has been improved quite well in recent versions but it needs to convert this as well, I havent found any “free” script that does this, only V-RayMax Converter PRO does it
Curved Decals on multiple Axys - this could be very useful for curved planar roads
Show LightCache in Composite - Like in Lightmix this could be very helpfull, right now I use all maps just to see how lightmix its working rather to just have backtobeauty
Select Objects with problematic materials in VFB Log - using 3ds max “Search by name …” tool its annoying, I use some scripts for this, if the Log warns you which material its problematic, could be very nice to have the option to select the objects too.
Porcentage/Probability in MultisubTex - This is very practical to have in some cases where you need a porcentage of some maps, right now the only “solution” is to have a subsecuential quantity for each map added
LightMaterial visibility Options - Could be nice to have them for a material like in vraylight
Exclude objects from VrayPhysicalCamera - I use States Sets or Scene Sets for this, but this could be very practical to have inside the Camera
VRay GPU supports more features like CPU. Rendering results (especially bumps) closer to the CPU
Faster Interactive Rendering with default settings.
VRay’s interactive rendering seems slower than Corona’s. May be caused by the default settings, but it is also the reason why many of my colleagues gave up on VRay.
UVWRandomizer in MultisubTex - I have an script that works for this, but this should be avaiable into the MultisubTex as Batch Load has been added
Have perpetual license also for new customers could be added into the wishlist? 8)
I don’t know if this has already been mentioned or not.
In VFB:
- the ability to copy/paste Compositing layers from one image to another
- the possibility of adding a layer to download an image (texture, color patch, etc.) to enable more precise color correction by close comparison.
- an error message when loading a .vfbl file and there’s a matching problem in Cryptomatte
Could you please enhance V-Ray’s Toon Line control?
First, port Maya V-RayToonMtl and ToonLine.
And provide detailed line control like PRman, ARNOLD.
For example, it would be nice to be able to put a line on the edge of the shadow.
https://rmanwiki.pixar.com/display/REN26/Stylized+Lines
https://help.autodesk.com/view/ARNOL…n_edge_html
Redshift has also implemented advanced Toon Line in its latest version.
Now, V-Ray’s Toon Line is only a minimal implementation.
Some sort of eye dropper tool for V-Ray’s camera to select an object to be in focus when using depth of field. Unreal engine has this feature and it is so nice to be able to quickly select my object to know that is the focus of my shot and adjust my camera settings from there.
Could it be possible that Vray sun has an Add Vraysky button?
Sometimes I merge suns from other files and I forget to add sky, and …well its not that this is very complicated to add it from Environment but it could be practical to have it inside the sun
Global Shadow Bias Override spinner
Perhaps somewhere in the settings tab this could be specified as some sort of override. I work in meters so every single light I make needs to be changed.
Chaos Scatter - Place mode (Place instanced geo by click, like ForestPack)
Vantage - White balance setting. Set alongside the other colour corrections (Exposure, Filmic, LUT).
